Forums >> Revit Structure >> Technical Support >> ceiling problem
Sat, Jan 10, 2009 at 7:52:30 PM | ceiling problem
maris327
I have problem getting ceiling plans in project browser (Revit Structure 2009). In Revit Arhitecture ceilings are near floor plans by default... But now I have started a project in Revit Structure using some Revit Structure template and I can't get the ceilings (the main reason to get ceilings is to get lights afterwards). Can anyone help me?
Sun, Jan 11, 2009 at 9:50:15 AM | ceiling problem
4 Stars: 205 Votes
Go to "View > New > Ceiling Plan"....
Tue, Jan 13, 2009 at 3:22:48 PM | ceiling problem
Keyholeren
From what i see, structure does not have the capability of adding a ceiling plan.  If you need a ceiling plan in your project browser on a regular basis, I would try using an architecture template.  I have been testing the two templates against each other and the architecture template seems to work fine in structure.
ceiling tag for mass created clg.
Mon, Jun 2, 2008 at 12:38:04 PM
problem with ceiling in groups
Tue, Nov 24, 2009 at 9:27:22 AM
Ceiling Problem
Fri, Nov 19, 2010 at 9:38:10 PM
Ceiling problem
Thu, Sep 4, 2008 at 6:12:33 PM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Page generation time: 0.8796
