16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> Can you create ducts in Revit structure?
83 Posts No Rating |
I have a project I am currently designing and there are several areas with large mechanical truck lines that I would like to put into my model so I can keep track of them. Can I do this?
I would recomend in-place families: 1. Under the Modelling tab, select the 'Create...' button. 2. Click on the 'Show categories from all disciplines' checkbox 3. Use a category of your choice; Air terminals, Generic Model, etc. Extrusions-based geometry should do just well. If you don't know what to do next let me know.
23 Posts No Rating |
hhwse, Make line-based generic model families with reqiured profiles and parameterise them for length, depth and width/radius. You can then use these for the ducting. You may have to use connectors, because I have found that the line-based families don't curve well. I am using Revit Architecture 2009 for making the entire Mechanical ducting for a 53,000 SF school building. Maybe the organisation would buy Revit MEP after this. Radhika.
thanks i will give it a try.
Linked CAD ducts/pipes not showing up in Revit Structure 2013 |
Fri, Jul 10, 2015 at 8:36:42 AM
13
QUANTITY TAKEOFF FOR DUCTS |
Mon, Apr 21, 2014 at 7:33:52 AM
system type in ducts |
Mon, Sep 24, 2012 at 11:55:48 AM
HVAC, Any Ideas? |
Mon, Jul 4, 2005 at 3:36:13 AM
Unselectable ducts, picture included |
Fri, Feb 20, 2009 at 1:56:09 PM
