Forums >> Revit Building >> Technical Support >> curtain wall
Sat, Jan 10, 2009 at 6:33:24 AM | curtain wall
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
could someone please explain something to me about curtain walls?..
when is it a window and not a curtain wall?
suppose you have a big opening in a wall where
you want the curtain wall to go inside that opening?
i can't put a curtain wall in a wall opening in elevation
view.. am i supposed to blindly put the curtain wall
in the wall opening from plan view?
Sat, Jan 10, 2009 at 8:21:30 AM | curtain wall
4 Stars: 205 Votes
Hi, see the video: http://screencast.com/t/IDHmPGNCK7
Sat, Jan 10, 2009 at 9:51:04 AM | curtain wall
forry
HEH This is quite helpful dude! I didn't know it too! But i tried to draw polygonal wall opening, but it makes curtain wall only aligned to two lines and it didn't work. Is there any solution for irregular openings? What about curtain wall by face?
Sat, Jan 10, 2009 at 9:54:53 AM | curtain wall
4 Stars: 205 Votes
You always have the option in "Elevation View" to pick in the curtain wall and "EDIT" then draw the shape you want....
 see the video: http://screencast.com/t/ncFDYmfJjc
Edited on: Sat, Jan 10, 2009 at 10:00:06 AM
Sat, Jan 10, 2009 at 10:01:35 AM | curtain wall
forry
Heh 10x! It works Smile!
Curtain Wall Panel to Curtain Wall Door
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Link curtain wall parameter to curtain panel
Wed, Jun 10, 2015 at 5:06:07 AM
Page generation time: 0.8236
