Forums >> Workflow & Implementation >> Hardware >> PC vrs Imac
Fri, Jan 9, 2009 at 3:46:52 PM | PC vrs Imac
hor4more
Well ..heres my problem..
i have a limited budget!! due to the fact that im a student...this last semester i used  a Sony Vaio VGN-Fe850Fe and
 my proyect had lots of geometry so ...my laptop kept crashing and just couldnt make a single decent render...soo heres my situation
do i buy
A) Imac 2.4 GHZ intel core 2 duo 4gb and 500 gb hard drive
 orrrrrr
B) Hp quad core 2.2Ghz, 8gb ram ,500 gb hard drive,...
the reason i post is that this hp has better specs but ive heard that the imac even with lowers specs might run better Revit ....
besides ive never been a mac user before and... i just hated when vista crashes or runs out of RAM..also Mac Pro is not an option its out
of my budget Thank!! any comment will help!!
Fri, Jan 9, 2009 at 3:53:46 PM | PC vrs Imac
hor4more
P.S my Sony Vaio is a VGN Fe850fe with 2 gb ram and inter(R) core(tm) 2 Cpu t5600 @1.83ghz ,windows vista 32 bits
again thanks to anyone that comments!!
Fri, Jan 9, 2009 at 6:29:38 PM | PC vrs Imac
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
The iMac is such a great, beautiful machine but you will have to purchase Parallels Desktop 4.0 to run Revit on Vista (64bit-recommended)  It's 80 bucks, maybe less with a student discount!
I have had much success in running Revit (zero crashes) and I have the exact same specs as the iMac one you described.
Just be sure to dedicate at least 2G of RAM to the Windows platform.
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Sat, Jan 10, 2009 at 12:04:48 AM | PC vrs Imac
hor4more
thanks for the comment...i read in other posts about it..its the only way to instal revit??...and i do use other cad programs such as
3dmax, and revit structure, ohhh and autocad (just in case) ...im actually hopping for the imac ... thanks!
Mon, Jan 12, 2009 at 8:25:20 AM | PC vrs Imac
vihi
You'll get more out of your setup if you use Apple's own Bootcamp (comes free with any new Mac) to boot into Windows when neccessary, instead of running a virtual machine. If you do it like that you can run any Windows application you want.
iMac performance drop with Revit 2010
Fri, Jan 29, 2010 at 8:24:47 AM
12
Revit 2011 on iMac in bootcamp windows 7 keeps crashing
Mon, Jul 1, 2013 at 1:13:28 PM
Revit + iMac + boot camp anyone?
Tue, Oct 30, 2007 at 2:02:01 PM
Buying new iMac...looking for advice
Sat, Aug 13, 2011 at 9:53:39 PM
Help with Revit and Macbook pro
Mon, Jun 22, 2015 at 8:05:08 PM
Page generation time: 0.0130
