Forums >> Revit Building >> Technical Support >> Fill Pattern Weight + Appearance
Fri, Jan 9, 2009 at 3:40:15 PM | Fill Pattern Weight + Appearance
FourStar
I am working with the Strip Footings-Section family and for some odd reason the fill is lighter for some footings than others.  Take a look at the example attached.  Kind of frustrating!  Any clues to what is going on.
Thanks
50766_Example.TIF
Fri, Jan 9, 2009 at 4:33:04 PM | Fill Pattern Weight + Appearance
tim123
4 Stars: 19 Votes
Are you sure that the element cut pattern properties have not been overidden?
Fri, Jan 9, 2009 at 4:40:44 PM | Fill Pattern Weight + Appearance
FourStar
Yea...I'm sure.  I haven't overidden anything.  These are the standard families from revit.  They are different sizes but that shouldn't matter.
Fill Pattern Weight
Thu, Dec 17, 2009 at 12:03:13 PM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Split face pattern line weight (2009)
Tue, Aug 19, 2008 at 2:57:25 PM
Page generation time: 0.2044
