Forums >> Revit Building >> Technical Support >> Rendering Split face block in RAC2009
Fri, Jan 9, 2009 at 12:02:01 PM | Rendering Split face block in RAC2009
pwiklund
I'm trying to render different split face block colors in 2009 but every time I don't use the standard coral SF image I just get a solid color.  I've bumped up the "bump" but i lose the course lines.  What at i doing wrong?  It doesn't seem to me that RAC 2009 handles the block rendering very well.  Do I have to find a .jpg image the type of block I want to render?
 Thanks,
Fri, Jan 9, 2009 at 4:26:35 PM | Rendering Split face block in RAC2009
tim123
4 Stars: 19 Votes
You will need a different mapping image.  Find the image and change the colour in photoshop or something similar and apply this to the different block.  Altenatively, find a picture of the blockwork and create a map from it using photoshop.
Mon, Jan 12, 2009 at 10:55:20 AM | Rendering Split face block in RAC2009
pwiklund
I think I've found a solution to my problem.  www.brick.com this website has a Masonry designer tool that lets you build a brick or block wall and export it out as an image.  You can then take it into photoshop or any image editor and crop the file down.  I don't think the resolution is as good as the images Revit comes with standard but it is a work around for now.
 Peter
Split Face Masonry Block
Thu, Aug 3, 2006 at 6:25:54 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:24 AM
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
Split face on floor?
Wed, Nov 18, 2015 at 1:16:28 PM
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:26 PM
Page generation time: 0.6398
