10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Looking for quick Key shortcut
8 Posts No Rating |
What is the Keyboard shortcut for 'element properties'? it's not 'EP'. I also can't find it in the Keyboard Shortcuts.txt. I'm using Revit Architecture 2009. Build: 20080915_2100.
PR
8 Posts No Rating |
AWESOME! THX TIM!
No trouble - its in the edid menu BTW.
8 Posts No Rating |
Sometimes the best hiding spot is in the most obvious place.
36 Posts No Rating |
In versions 2010, I was trying to find a way to customize the "PR" shortcut-- Like many other users, I prefer a quick left handed shortcut for such a common and frequent task (that way I don't have to look at the keyboard and can work faster). In v.2009, I had "``" (up by the esc key) set to take me to element properties, but now that the program has been re-worked, it looks like I can no longer customize this function. Has anyone figured out a work-around, or should I just start re-training my muscle memory to hit "PR" now? Thanks in advance.
You can still change it. See image.
Thank you, that is just what I was looking for! This new format will take some getting used to...
repeat command shortcut key?? |
Tue, Aug 19, 2008 at 2:15:12 PM
shortcut key for text |
Tue, Jul 25, 2006 at 6:26:09 PM
Shortcut Key to Rotate 3D View |
Wed, Dec 1, 2010 at 4:06:52 PM
Deleting Problems (Revit 2009) |
Mon, Oct 27, 2008 at 9:21:15 AM
Keyboard shortcuts |
Wed, Jul 2, 2008 at 2:14:29 PM
