9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> cropping plans and titleblock parameters
25 Posts No Rating |
im facing two problems which i need to resolve immediately
1. is there a way i can crop plans in shapes other than rectangles or squares? for example like a polygon?
2. in my title block i want to creat ea new parameter for room no which i can edit for each individual sheet. so i made a label in ym title block and called it room no and then created a new parameter and brought it to my project file. the label somehow ends up being non editable and appears as a question mark in the file. wat am i doing wrong?
1. No, its on the wishlist and has been for quite sometime.
2. You have to load the shared parameter into the project and apply it to drawing sheets. File-->Shared Parameters and check the appropriate SP is loaded. Then goto settings-->Project parameters, load the SP and then tick the drawings sheets to have this SP be applied to them. Then set whether you want this to be instance or type based.
HTH.
BTW, what is up with this site lately its so slow!!! It might come good for a day then its pathetic again? Moderators?
Instance Parameters in titleblock not linking |
Wed, Dec 28, 2011 at 10:31:23 AM
12
Titleblock Parameters [ 1 2 ] |
Thu, Mar 13, 2014 at 4:57:53 PM
17
How to link shared family parameters into an assembly titleblock? |
Mon, Apr 20, 2015 at 8:14:15 AM
Titleblock Parameters |
Mon, Mar 19, 2007 at 11:12:52 AM
Drawn By and Checked By titleblock parameters |
Fri, Oct 10, 2008 at 10:43:12 PM
