Forums >> Revit Systems >> Technical Support >> Air Terminal Tags question
Thu, Jan 8, 2009 at 5:26:52 PM | Air Terminal Tags question
silverdreams2000
Is it possiable to make a tag that differentiates between Supply Diffusers, Return grills, etc? My company standards are so that if it is a supply Diffuser, the mark has a square around it and the cfms are in a rectangle below, if it is a return grill the mark is surrounded with a triangle and the cfms are in a rectangle below. Is there a way to make one tag to automatically do this for me?
Thu, Jan 15, 2009 at 5:05:47 PM | Air Terminal Tags question
jayspot
jayspot Avatar
I don't think there is a way to make it automatic.  I solved this problem by creating two separate tags, one for supply and one for return.  We use the same tag for all diffusers, but use a dash (-) for the CFM on the return air diffusers.  Therefore, I made a diffuser-return tag without the CFM label and put a text dash in its place.
www.revitgarage.com
Tue, Feb 9, 2010 at 11:52:23 AM | Air Terminal Tags question
JillBernhardt
5 Stars: 3 Votes
Yep, there is no way to make this automatic as the software lumps all diffusers, grills, etc. into a category of Air Terminals as shown in the screen capture below.  You can make as many different types of air terminal tags as you would like however, just create the types you need and switch back and forth between them using the pulldown circled below as necessary.  Tag a number supply diffusers for example, switch your tag out in the dialog and then tag a number of return grills for example.
Jill Bernhardt
    Blog:  The BIM Bulletin
fancoils families and air terminals families
Thu, Jul 28, 2011 at 2:48:19 PM
is it possible to array air terminals on a duct?
Wed, Aug 10, 2016 at 4:32:09 AM
Return Air systems help? Please
Tue, Feb 9, 2010 at 11:42:41 AM
create new connector system type
Fri, Sep 18, 2009 at 3:55:39 PM
Duct System problem
Thu, Jan 10, 2013 at 9:23:22 AM
Page generation time: 0.7298
