25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> section tags
25 Posts No Rating |
im trying to come up with an easy way to put details for specifications in sections for my wall finishes and floor finishes etc. i thought maybe if i created a tag where i have it show the description it wld work. but my problem is that it wont let me tag anything besides my furniture and columns or beams. i created it as a multi category tag. any ideas? im specifying wall finishes for every space (its a large 4 storey bldg) and i want to be able to just click on the wall and tag it and have it just tag the finish. is it possible? also can i put room tags in sections?
13 Posts No Rating |
im not to sure about specific tags as wall, ceiling, furniture are only specific to each family. I have used keynotes in the past to call up particular finishes. This is the easiest as you can give the keynote specific parameters that can be scheduled bu using the note block function.
Hope this helps.
section tags for broken wall sections |
Fri, Dec 7, 2007 at 10:57:25 AM
Section Tags missing (again) |
Wed, Aug 26, 2009 at 10:50:38 AM
Floating Section Tags |
Mon, Nov 26, 2007 at 1:09:03 PM
room tags in section |
Wed, Jan 10, 2007 at 11:22:58 AM
Elevation Tags not showing when I cut a Section View |
Mon, Oct 20, 2014 at 2:43:05 PM
