15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> dividing lines
26 Posts No Rating |
Basic question about Revit 9 drafting: Is there an easy way to divide lines into a specified number of equal segments, as one would with the Divide command in AutoCAD? Thanks!
It can be done in a round about way. Draw the line the overall length and then draw lines perpendicular how ever many spaces you need. Next place a single dim string across all the lines and toggle the EQ for the string. This should adjust all of the perpendicular line to equal spaces. you will then use the split tool to break up the original line.
How do you toggle the dimensions into equality? When I try to do that, Revit adjusts the length of the line, not the lengths of the dimensions. Thanks
yOU CAN ADD AN OVERALL LENGTH DIMENSION AND LOCK THAT ... THEN TOGGLE THE EQ ON THE OTHER STRING sorry for the caps
have a look http://screencast.com/t/cLd7m0tL HTH
Follow coreed's video. That is exactly how i did it.
Sorry to be so long getting back to this. Thanks very much for the help. My dimension snaps seem to work a little differently than yours... have not done much with Revit dimensions yet, as I'm using it more as a modeling tool right now. Don't quite follow how you got that initial EP snap on the horizontal line, but was able to make the technique work.
Hover your mouse over the endpoint and push tab key until you see the dot.
Thanks!
No dividing lines on sections ? |
Sat, Mar 14, 2009 at 2:39:37 PM
dividing project and linking files : structure, interior/envelope walls |
Wed, Apr 6, 2005 at 6:22:48 PM
Help dividing surface of imported .sat file to create curtain system |
Sat, Nov 13, 2010 at 12:44:51 PM
dividing line |
Wed, Jul 12, 2006 at 12:38:09 AM
Section cut lines |
Tue, Feb 2, 2010 at 9:44:41 AM
