21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Turn off a category in multiple views - efficiently
4 Posts No Rating |
I have my interior elevation sheets layed out and need to turn the furniture off/on depending on the purpose (furniture off for the main CD's, but on for the FF&E). I know in AutoCAD I could simply turn the layer off; does is there a way to quickly turn the furntiure off for all interior elevation views? I know how to use VG to turn it of view by view (soo tedious). Thanks for the help.
Create a view template for each condition - you can then apply these to multiple views.
you could use a view template, select all views in the broswer that you want it apllied to, right-click and apply the template
4 Posts No Rating |
Wow - it worked perfectly, thank you to you both! You saved us a lot of time and frustration.
I would take this one step furthur than what coreed says. After you right click on the single or multiple views, assign the template you want to these views. Do this with all your views (other than special single type of views) so that when you need to print, you can multiple select all the sheets in your project and choose "apply default view template". Then all of your vies will be correct for printing no matter who may have been working on them. Any view not assigned a view template will not be affected by this.
4 Posts No Rating |
I see the choice to "Apply Default View Template to All Views", however, I do not know how to set the default view template. This is a great tip, and I would appreciate the steps on how to set it.
Do what I said .... select your views - then right click and under properties you will find the parameter "default view template" ... when you click on that, there will be a pull down on the right where you can select the template you want to assign
Design Options - Efficiently Changing Option Visibility in Multiple Views |
Wed, Nov 29, 2006 at 11:26:41 AM
how visibility of filter work with the turn on/off of certain category? |
Thu, Jan 13, 2011 at 4:03:48 PM
Exporting multiple 3D views |
Mon, Jul 15, 2013 at 9:08:22 PM
Change a mass category |
Thu, Oct 4, 2007 at 10:47:01 AM
Using Region (hatch) in Multiple Views |
Wed, Mar 14, 2012 at 8:41:05 AM
