Forums >> Revit Building >> Technical Support >> Section Lines not showing up on a plan
Thu, Jan 8, 2009 at 8:32:00 AM | Section Lines not showing up on a plan
RNLRNL
I have section lines which cut through the building but aren't showing up on the roof plan. I have checked the hide unhide command and they aren't hidden. I have checked that the sectyion lines should appear on the scale I am working to and in the course mode so this isn't the issue. On floors lower down some section lines appear and other dont.
Is there a parameter to control on what heights section lines will be visible or are thre any other suggestions to resolve this problem.
Thu, Jan 8, 2009 at 9:32:28 AM | Section Lines not showing up on a plan
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The section symbol will only show up if the vertical extent passes into the view range. If a section doesn't show you will need to adjust the top extent until it does.
Section lines disappear
Thu, Nov 26, 2009 at 5:14:07 PM
Lines not showing on elevation and cross section views
Tue, Mar 12, 2013 at 7:43:57 AM
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Missing Section Marks on Floor Plan
Wed, Jan 2, 2013 at 4:13:20 PM
13
Building Section callout not showing in plan views
Fri, Mar 11, 2016 at 3:41:54 PM
Page generation time: 3.4931
