17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Detail Component line weights
21 Posts No Rating |
How do I get heavier lines in a detail component? The only choices for lines that I have currently are Detail Items, <invisible>, hidden, heavy, light, and medium. I need a line that is heavier than the 'Heavy' Line. However, I can not access line styles to make a new line type.
38 Posts No Rating |
It should be under object styles.
OH! They're considered objects! I see now! Thanks!!
Edit the component family and there you can add additional category lines ... ie SUPER HEAVY ....
where/how do I add category lines?
If you mean you want to add new line catagories to the list, just click new under "modify subcatagories."
yea, I just realized what you meant and figured it out. Thanks for your help!
The object style has to be added in the family - not project. It will come in when you re-load the family
Detail Lines Follow Model Line Weights Problem |
Fri, Sep 9, 2011 at 9:55:51 AM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Line Weights of Detail Components |
Fri, Jul 7, 2006 at 9:02:06 AM
Line Weights not showing in View |
Tue, Jul 8, 2014 at 12:45:18 PM
Vertical line-based detail component? |
Tue, Jun 3, 2014 at 2:30:53 PM
