Forums >> General Discussion >> Revit Project Management >> multiple section references
Wed, Jan 7, 2009 at 10:00:39 AM | multiple section references
stodwyer
1 Stars: 1 Votes
Hi,
  Im currently workign on a project where i need to produce detail 1:20 sections around the perimeter of a building. The building is easy enough. its a rectangular shape, so the east and west sections are the same and similarly with the north and south. When i generate sections along the north face can i copy the section reference to the southern face as the sections would be identical only for grid references?
  Can this be done or does revit only give you a section of an exact position and can the tag be copied as a reference?
 Sean
Thu, Jan 8, 2009 at 2:56:42 PM | multiple section references
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You will need to use the "Reference other View" feature. Start by making the actual sections on one wall. For the sections on the other wall you will go into the section tool and before you pick a location you will select "Reference other view" at the top of the screen. This will allow you to select a section view to reference to. It will also show the same number in the symbols. Do this for all the sections you want to "duplicate"
Revit 2011 Multiple Interior Elevation References
Wed, Oct 26, 2011 at 9:01:48 AM
Section References Disappearing
Sun, Sep 13, 2009 at 11:40:02 AM
Turn off section references that occur in the background of an elevation
Wed, Jun 16, 2010 at 2:10:12 PM
Section drawing references
Fri, Jun 21, 2013 at 11:46:25 AM
View References... how do they work?
Wed, Feb 27, 2008 at 3:00:42 PM
Page generation time: 0.2748
