Forums >> Revit Building >> Technical Support >> RENDERING QUESTION
Tue, Jan 6, 2009 at 11:01:52 PM | RENDERING QUESTION
paulykustomz
paulykustomz Avatar
In AutoCAD when you render you have the option to choose a jpg for the background. Cand you do that in revit 2009?
basically can I pic a background instead of just using the default?
thanks in advance
Tue, Jan 6, 2009 at 11:11:25 PM | RENDERING QUESTION
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, but its post processing.  Export out to PNG or TIF format and the background is exported on an alpha channel allowing you to put in a new background in photoshop or gimp.  If you don't have either of these softwares you can do it by capturing the rendering to the project, putting the background on the sheet, then dragging on the rendering.  The alpha channel is activated...
Regards,
Chris.
Tue, Jan 6, 2009 at 11:22:52 PM | RENDERING QUESTION
paulykustomz
paulykustomz Avatar
thanks MR.Spot
you rock
Wed, Jan 7, 2009 at 1:08:01 PM | RENDERING QUESTION
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi paulykustomz....for more reference watch this video: http://www.cadclips.com/Revit-2009-CadClips.htm. Hope it can help you....
NEWBIE QUESTION... RENDERING??
Fri, Jul 23, 2010 at 2:03:16 PM
rendering
Tue, Sep 21, 2010 at 9:45:53 PM
NEWBIE Question: Confused about rendering...
Mon, Mar 2, 2009 at 11:46:53 AM
Rendering Question
Mon, Apr 30, 2012 at 7:55:09 AM
Rendering...
Fri, Aug 8, 2008 at 2:43:22 AM
Page generation time: 2.8764
