Forums >> Revit Building >> Technical Support >> how to erase Viewport Tags
Tue, Jan 6, 2009 at 5:42:25 PM | how to erase Viewport Tags
bert
Hello all,
I'm setting up our office's template, and wanted to erase two viewport tags I no longer need. I thought I could purge them out, and renamed them to find them easily (see image: delete 01 & delete 02), but I can't.
They are not in use in any view, and I don't seem to be able to locate them in any way.
Any help would be appreciated. Thanks!!
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Tue, Jan 6, 2009 at 11:29:14 PM | how to erase Viewport Tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Provided they aren't in use, Just do a purge unused.  They will show under other sytyles-->Viewports
Regards,
Chris.
Wed, Jan 7, 2009 at 9:14:36 AM | how to erase Viewport Tags
bert
That was my reasoning too, except that, after checking all viewports, I know for sure those styles are not in use.
So here's what I did: I made a copy of the file and deleted all sheets and checked the purge tool; still nothing showed up. I then proceeded with all views & legends: still nothing. I then continued with all the schedules and was able to narrow it down to two schedules that apparently have these viewport tags associated with it.
Oddly enough, these schedules are working schedules so I've never placed them on a sheet. Furthermore, without any sheets, how can they have a viewport tag associated to them???
I've also copied the schedules into a blank file and the viewport styles were carried over...
I've checked everything about them, and can't find the answer, so I'm really curious about this one.
using RAC-2013
viewport tags
Thu, May 6, 2010 at 3:18:49 PM
Viewport larger then needed on sheet
Tue, Feb 20, 2007 at 10:38:25 AM
Draw Order of Viewport on a sheet
Wed, Dec 16, 2009 at 4:35:58 PM
Double section tags
Mon, Nov 5, 2007 at 4:49:38 PM
viewport annotation box
Mon, Jun 2, 2014 at 8:49:40 AM
Page generation time: 0.5499
