Forums >> Revit Building >> Technical Support >> Revisions Isuued on new titleblock??
Tue, Jan 6, 2009 at 3:35:08 PM | Revisions Isuued on new titleblock??
jeffrb25
Revit Architecture 2009
I am started an addendum and cannot figure out how to solve this issue.  I want to take a linked autocad detail view which is linked to the sheet, cloud it in the detail view to show up in the parent sheet then take that detail place on a new titleblock (8.5x11) with the addenum information.  Basically, want to reisue the detail and not the entire sheet.  How can this be done?
Tue, Jan 6, 2009 at 3:39:39 PM | Revisions Isuued on new titleblock??
There was a discussion on AUGI last year that had a sketch titleblock family that you could overlay over your sheet .... it hides everything except a window.   I'll look for the link
here is the link  http://forums.augi.com/showthread.php?t=53492
We now use this system
Edited on: Tue, Jan 6, 2009 at 3:42:23 PM
Tue, Jan 6, 2009 at 4:44:38 PM | Revisions Isuued on new titleblock??
jeffrb25
Great thanks, I will give it a try.
Tue, Jan 6, 2009 at 4:56:53 PM | Revisions Isuued on new titleblock??
jeffrb25
How do I create the sketch overlay for the titleblock and a Revision View?
Wed, Jan 7, 2009 at 9:21:54 AM | Revisions Isuued on new titleblock??
Read the posts in the link I gave and look at the family that was posted there.
Tue, Jul 28, 2009 at 4:09:07 PM | Revisions Isuued on new titleblock??
timhill
I'm confused about Kingham's suggestion with the masked titleblock.  Basically about how he keeps track of the various sketches.  We number our sketches where I work and I don't see how you can really do that with this method.  Also, it doesn't seem like a super neat way to print - like how do you ensure all the changes have been published in the addendum.  Just seems crazy all over the place, but then so does duplicating views.
Tue, Jul 28, 2009 at 4:56:10 PM | Revisions Isuued on new titleblock??
This really works.  We have our sketches numbered by sheet and by revision issue.   In other words Revision 1 incfludes....Sheet number-Sketch number etc.  We make a pdf then delete the overlay.  The PDF is your record and no need to keep anything else.  No need to keep track of sketch numbers because the numbers re-start at each revision.
Tue, Jul 28, 2009 at 5:18:38 PM | Revisions Isuued on new titleblock??
timhill
I think our process might be more complicated than necessary.  We actually continue the numbering across revisions so the addendum number is sort of irrelevant.  ASK-14 could be in addendum 2 or 3 or 4 - either way, it is still ASK-14, and there is only 1
then there is an item # in the body of the addendum - for instance, item #A-7 might be REVISE - sheet G000 with attached sketch ASK-14
then, we draw the revision cloud around the change and type in the item number under the triangle.  that way, the body of the addendum legally states the change, and revision cloud references back to the addendum item #.
We have not figured out the revision list yet - so you use a separate schedule that lists the sheet revised and the sketch number?  and then just place that on the title sheet next to the sheet index?
Revisions in the Titleblock
Wed, Dec 2, 2015 at 2:18:27 PM
Title Block Revisions Question
Tue, Oct 7, 2014 at 7:16:21 AM
revisions display issue [ 1 2 ]
Mon, Sep 15, 2014 at 3:23:27 PM
15
My revisions schedule won't go over 10 revisions
Wed, Oct 14, 2015 at 6:37:09 PM
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Page generation time: 0.0635
