Forums >> Revit Building >> Technical Support >> line weight consistancy and views??
Mon, Jan 5, 2009 at 5:42:47 PM | line weight consistancy and views??
rquist
in general my stairs, toilets, tubs, washer/dryers, etc are defaulted to grey color and a lineweight.
if I override the line weight, color and pattern thru "view properties", "element props" and "vis/graphics" override will I have to go into each view and change the default.  If so is there a way to change these project wide?
Tue, Jan 6, 2009 at 6:01:47 AM | line weight consistancy and views??
tim123
4 Stars: 19 Votes
Change them in the object styles, under Settings.
Wed, Sep 2, 2009 at 9:05:41 AM | line weight consistancy and views??
marcpinard
this forum is great, this is the exact answer I needed when I searched
LINE WEIGHT PROBLEM IN PRESPECTIVE
Tue, Mar 13, 2012 at 3:26:45 PM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:55 PM
line weight question
Fri, Jul 20, 2012 at 8:24:10 AM
Page generation time: 2.9717
