Forums >> Revit Building >> Tips & Tricks >> How to create a dome
Mon, Jan 5, 2009 at 5:29:59 PM | How to create a dome
sigma
Hi all, my name is Sigma and I have been using Revit since 2007. . Currently I am trying to create a dome and became frustrated. Any suggestions from the forum will be appreciated.
Do you folks use create mass or place mass? Or you use the library and rename and change the object? May be I am wrong please feel free to make comments.
Mon, Jan 5, 2009 at 6:27:05 PM | How to create a dome
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
The easiest way is to create a mass the correct size, then use the "wall by face" function
Mon, Jan 5, 2009 at 10:26:44 PM | How to create a dome
sigma
Hi alabaster. I need more explanation. If you could give me the steps then I can follow. Thanks again.
Tue, Jan 6, 2009 at 12:02:25 PM | How to create a dome
JRMello
Use the Create Mass tool, and most likely, create a solid revolve in the size and shape you need. Once you have finished that solid, and the family you can then use the Wall by Face tool to apply walls to the surface of your mass.
HTH
Tue, Jan 6, 2009 at 1:23:06 PM | How to create a dome
If you want these to be "walls" then the previous post is correct....
You can also do an in-place family ... set to be whatever category you want - probably not walls.  Do that as a revolve and the profile thickness appropriate for your structure.
Tue, Jan 6, 2009 at 2:20:56 PM | How to create a dome
sigma
It's working and thanks to both of you.
Create a half dome
Mon, Nov 11, 2019 at 5:37:42 PM
Dome roof
Mon, Jan 17, 2011 at 7:52:22 AM
14
Create a dome
Tue, Apr 24, 2012 at 12:50:06 PM
a dome of glass ??? [ 1 2 ]
Wed, Nov 26, 2008 at 1:48:50 PM
17
Dome Roof for a Church Project
Mon, Jan 19, 2009 at 2:44:53 PM
Page generation time: 1.1118
