10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Countertop Invisibility
11 Posts No Rating |
Ok here is my issue, This seems pretty simple but I am having trouble getting the cabinets underneath my countertop to not show up. I made sure that the countertop visiblity was correct and I made sure that lineweight has not been changed. What is going on. Why can't I tell the countertop to not show the things below it? I hope someone can help. Thanks,
Are you sure your countertop is on? .... is your countertp a 3d object or masking region? ... is your counter top inserted at the right elevation?
I know that the countertop is turned on and is a 3d object. I also know that it is set at the right elevation
If the coutertop is a 3d object that is one thing... are you sure the extrusion is set to be on in plan in the family? Otherwise ... unless your view is cutting below the counter - it will hide the cabinets below.
How do I add a countertop to the Base Cabinet - Corner Unit Angled? |
Tue, Mar 28, 2006 at 3:39:10 PM
Anyone ever put a countertop on a wall as a sweep? Anyone? |
Wed, Nov 15, 2006 at 3:42:51 PM
cannot get sink at countertop elevation (revit 2013) |
Wed, May 7, 2014 at 12:16:09 PM
Mass in Place Countertop |
Thu, Dec 8, 2011 at 7:01:41 AM
invisibility below grade |
Fri, Jun 29, 2007 at 9:38:06 AM
