Forums >> Revit Building >> Technical Support >> 64 bit Revit 2009 WILL NOT INSTALL!
Sun, Jan 4, 2009 at 12:38:31 PM | 64 bit Revit 2009 WILL NOT INSTALL!
vanderloo
I don't know where to go with this but I've tried any and everything I could think of and I can not get Revit 64 bit to install. I did have it installed twice but it was so unstable I uninstalled and tried re-installing. The first time I got it to install after several attempts. Again very unstable. Then, after uninstalling, it WILL NOT INSTALL! I would have to write a novel here to list everything I've tried, including wiping out the registry, uninstalling all autodesk products and trying to install. Does anyone else have Revit 64 bit on a Dell Precision M90? Wondering if there are compatibility issues here. When installing, I get "This data is invalid" on 5 out of 8 folders. I'm on xp pro64, 150 gb HD, 132 gb free space, 4 gb ram, intel dual core processor. I also did a complete diagnostic with Dell tech support. ALL OTHER APPS RUN PERFECTLY on this machine. Please help.Thanks,Phil
Edited on: Sun, Jan 4, 2009 at 12:44:25 PM
Mon, Jan 5, 2009 at 7:23:17 AM | 64 bit Revit 2009 WILL NOT INSTALL!
coreed
coreed Avatar
4 Stars: 16 Votes
did you try re-downloading the 64-bit version form the subscription center. maybe your original download was corruppted.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jan 5, 2009 at 9:42:08 AM | 64 bit Revit 2009 WILL NOT INSTALL!
vanderloo
Downloaded it 5 or 6 different times. Got a downloaded copy from my reseller, downloaded to another computer, burned a disk and tried that. Same results.
64 bit install and (x86) folder
Thu, Jan 1, 2009 at 2:27:59 PM
Service Pack Won't Install Revit Architecture 2009
Sat, May 29, 2010 at 5:18:39 AM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
Revit 2009 and Windows 7
Fri, May 14, 2010 at 7:56:23 AM
2010 and vista 32-bit
Thu, May 7, 2009 at 10:40:48 PM
11
Page generation time: 5.8508
