18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> CMU hatch origin
83 Posts No Rating |
How do you modify the starting point of the surface hatch pattern on a CMU wall. In AutoCAD you could set the UCS origin to the corner you wanted to start you block module and it was fine but I can’t find the same function in Revit.
Very easy in Revit - click on one of the hatch lines (you may need to use the tab key to do this) and move it to where you would like it - or rotate it.
Or you can use the "Align" tool....
thanks, that works perfectly. I knew that it had to be something simple.
CMU Hatch Patern |
Sat, Jan 31, 2009 at 4:00:05 AM
How to set the origin for hatch in revit |
Fri, Sep 16, 2016 at 3:03:45 PM
CMU Wall |
Thu, May 7, 2015 at 12:15:47 PM
CMU wall - hatch pattern not showing in plan view |
Wed, Aug 27, 2014 at 2:57:54 PM
What is the best way to hatch a CMU Wall? |
Wed, Nov 4, 2009 at 7:00:29 PM
