13 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Getting "Not enough Memory" error
Hi All, Happy New Year. I've been getting this error message "This Computer Does not have enough memory to load,...." When I try to load family files and sometimes when I try to open projects. My files are very small, (7224kb), and the operation of opening miniscule family files is obviously not a memory intensive procedure. I'm running windows xp pro64, Revit 2009 64 bit. 150gb HD with 132g free space, 4gb ram, Intel dual core processor, virtual memory paging set to 2046/4092. Task manager processing tab shows Revit at 500,000k. Revit is the only program open, 1 project only. Seems to be a software/ hardware communication glitch as I have more than enough memory. Been going on for 3-4 weeks now. I have to shut down and re-open Revit every time this happens. I have had zero other software/hardware issues with this computer. I have uninstalled and re-installed Revit at least 5 or 6 times. The only other Revit issue is that; every time I use the Room tool and click the "show bounding elements " button, Revit crashes. my reseller tech support suggests I start by unloading all software, wiping out my hard drive, reformatting and installing Revit only and see if I can re-create the message. No really. That's what they said. Kind of like telling somone with a headache to start by getting a lobotomy! Thanks
Sorry, Had to add that I have installed sp3 the latest update I'm aware of.
In checking further, it seems odd to me that, even though I deleted all Revit folders from my c drive after uninstalling and before the re-install, I have Revit Architecure file folders in both my program files and my (x86) program files folders. But I only have 64 bit installed. Does anyone know if this is right and/or if this might cause a software conflict?
Error in RAC 2009-RENDER |
Thu, May 22, 2008 at 4:28:46 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash |
Tue, Jul 28, 2009 at 1:36:33 AM
Print Error "Display Error" |
Tue, Dec 20, 2005 at 5:04:34 PM
Revit "appcrash" error |
Tue, May 25, 2010 at 2:48:11 PM
Revit 2009 Out of memory |
Tue, Oct 29, 2013 at 11:58:44 AM
