11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Dividing a 2d line
17 Posts No Rating |
I`m just wondring about if there is a comand in Revit 7 that divide a 2d line in several parts in same size. In AutoCad there is a comand called "divide".
I`m new in Revit, so maby the question is not so clever... ;
Hope someone can help me.
Thanks, Stian
Post edited on 2005-05-26 03:28:11
In Revit you can use dimensions to control equality. You could set up reference planes for instance, add a dimension string to them, then click on the little blue "eq" control and then they will all be equally spaced. Since this equality is maintained even if the outside lines move, it is vastly more powerful than the ACAD divide command. Revit is all about levels, grids and alignments use them to your advantage.
HTH
Tom
Dividing a line |
Tue, Sep 4, 2007 at 9:06:00 PM
dividing project and linking files : structure, interior/envelope walls |
Wed, Apr 6, 2005 at 6:22:48 PM
Line weights for hatch? |
Mon, Mar 23, 2009 at 2:24:48 AM
No dividing lines on sections ? |
Sat, Mar 14, 2009 at 2:39:37 PM
Help dividing surface of imported .sat file to create curtain system |
Sat, Nov 13, 2010 at 12:44:51 PM
