Forums >> Revit Systems >> Technical Support >> No "ROOMS" tab
Tue, Dec 30, 2008 at 12:10:57 PM | No "ROOMS" tab
caveman
I'm working with Revit MEP 2009 and am trying to set up a file linking the customer's model to my template but There is no "ROOMS" tab when I use the "Copy/Monitor Options" tool. Am I missing something? Am I setting it up wrong? I'm fairly new to Revit but I believe I was following the directions properly to that point. Any help?
Mon, Jan 5, 2009 at 4:27:50 PM | No "ROOMS" tab
jayspot
jayspot Avatar
I have some instructions on my website that might help you out....
 http://www.revitgarage.com
www.revitgarage.com
Tue, Jan 13, 2009 at 4:19:33 PM | No "ROOMS" tab
caveman
PERFECT!! It seems that ROOM BOUNDING was where I was going wrong. Thanks for the help!
Rooms within Rooms
Fri, Aug 7, 2009 at 4:18:34 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Room Tags Indicating Rooms on Different Levels - Revit Architecture 2009
Wed, Jun 4, 2008 at 12:09:35 PM
Room Numbers in Schedules
Wed, Jan 18, 2006 at 3:14:24 PM
Room Schedules: Using "Count" in Calculated Vaules....???
Fri, Dec 10, 2010 at 1:02:21 PM
Page generation time: 3.0914
