Forums >> Revit Building >> Technical Support >> Exporting Topo to STL as a solid for 3D Printing
Tue, Dec 30, 2008 at 10:22:58 AM | Exporting Topo to STL as a solid for 3D Printing
PSDABIMWIZ
I am attempting to export a .rvt file to .stl file for 3D Printing for the first time.  The architectural families export fine but the topography is absent in viewing the .stl file.  I was told by the 3D printing company that the most likely reason is that Revit may be creating the topo as a landscape oblect (surface) vs architectural componants (solid). Is there any way to convert the topo within Revit Architecture 2009 so that it will export as a solid to .stl file for 3D printing?
Fri, Sep 26, 2014 at 4:25:50 AM | Exporting Topo to STL as a solid for 3D Printing
PetraS
I have an exact same problem (6 years later,haha). Anybody figured it out since? Thank you.
Tue, Apr 18, 2017 at 11:31:00 AM | Exporting Topo to STL as a solid for 3D Printing
nathenial
Same problem 9 years later....
Fri, Feb 9, 2018 at 4:51:21 AM | Exporting Topo to STL as a solid for 3D Printing
Reusser
2.5 Stars: 3 Votes
10 years
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:31 AM
STL export tips
Mon, Nov 22, 2010 at 10:33:33 AM
How to make Families have Solid Material? .stl export trouble
Tue, Mar 12, 2013 at 9:52:34 AM
.stl file creation?
Thu, May 17, 2007 at 12:50:53 PM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:41 AM
Page generation time: 1.2489
