23 Users Online (21 Members):
Forums >> Revit Building >> Tips & Tricks >> Hidden Beam
43 Posts No Rating |
Could anyone give ideas on how to build a arcade? I am trying to figure out how to surround a column with stone, and then cover the beam so it looks like an arch. Please see the image attached. Than will make it more clear of what I'm trying to do. Right now, I just have the column, and a wall in front of it, with the arch shape. However this won't work forever. any ideas? how cal I surround the column with this stone?
Matias Santini |
It looks like you want a wall. Create the wall.Edit the profile to get the shape of the arcade openings right. Create a second wall for the stone veneer. Join the geometry.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
I end up surrounding the columns with a simple wall (with the stone material), adding the beam on top of the column, and a wall right under the beam, with the arc shape. still not very pretty, but it works for now. if you have other ideas, they are more than welcome! thanks!
Matias Santini |
Hi there, see the video: http://screencast.com/t/wlTgtvvvd
thanks typhoon ! That was great! I had something similar but your design is better. Matias
Matias Santini |
Beam/Beam Intersections of Multiple Depths - Hidden lines? |
Fri, Mar 23, 2007 at 1:23:59 PM
Automatic extension of Beam |
Tue, Jan 24, 2012 at 3:24:46 AM
Show Hidden Line - Not working the way I want it to |
Mon, Nov 19, 2012 at 10:52:43 PM
opening in concrete beam |
Tue, Jan 18, 2022 at 10:38:56 AM
Symbolic Lines in Beam Families |
Mon, Feb 24, 2014 at 3:54:58 PM
