24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Door Family/Glass Issue
11 Posts No Rating |
Hello Everyone, My issue is that I need to have a door family that has variable door swings/glass locations. I need the glass to move from one side of the mullion to the other. I have attached an image and I was hoping that someone could help me with this. If you don't understand what I'm asking please reply and I will try and word things differently. Thanks,
You must create Ref. planes with dimensions and add labels (parameters) and attach the element to those Ref. planes, so when you flex the family the glass also increase....
You could set this up with glass built on both sides then control the visibility of the glass extrusions using a yes/no parameter.
Thanks a bunch. The yes/no parameter worked wonderfully!
OOTB DOuble Glass 1 door issue |
Tue, Sep 23, 2008 at 3:56:09 PM
Frameless shower glass door |
Fri, Jul 9, 2010 at 11:50:11 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing |
Mon, Jan 19, 2015 at 7:41:36 AM
Overhead Door Family |
Mon, Oct 8, 2012 at 9:38:20 AM
Glass in doors transparent only on one side - any ideas? |
Sat, Jun 7, 2025 at 1:32:50 PM
