Forums >> Revit Building >> Technical Support >> Edit Cut Profile
Wed, May 25, 2005 at 1:48:09 PM | Edit Cut Profile
TracyA
Can anyone thell me if there is a way to modify the line weight of an edited profile so that the line is not so wide? Thanks in advance.
Wed, May 25, 2005 at 3:39:09 PM | RE: Edit Cut Profile
TomDorner
4.5 Stars: 25 Votes
Two ways: 1. Use the thin lines icon to turn off line thickness during your profile edit. 2. Set the "Sketch Lines" to whatever thickness and color you want. It is under "Settings" "Linestyles" then click the plus icon and go the "sketch lines" HTH Tom
Thu, May 26, 2005 at 10:22:20 AM | RE: Edit Cut Profile
TracyA
Hi Tom, Thanks for the tips. However I tried both and when I'm done sketching the profile and turn off the thin line icon the line still comes out as a really wide line. Any further clarification would be greatly appreciated. Thanks again, Tracy
Thu, May 26, 2005 at 10:56:03 AM | RE: Edit Cut Profile
TomDorner
4.5 Stars: 25 Votes
I assumed that you were talking about the thickness of the sketch line itself. Sounds like you really want to control what the wall looks like instead. If this is the case, go to "settings" "object styles" and set new line thickness for cut and projection styles. Tom
Thu, May 26, 2005 at 11:08:43 AM | RE: Edit Cut Profile
TracyA
That did it. Thanks for your help. Tracy
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
Edit Cut Profile
Tue, Dec 20, 2011 at 6:00:24 AM
edit cut profile
Mon, Aug 2, 2010 at 1:18:58 PM
Edit cut profile line thickness
Wed, Nov 18, 2009 at 12:15:27 PM
metal deck cut profile
Thu, Nov 4, 2010 at 9:17:43 AM
Page generation time: 3.1529
