Forums >> Revit Structure >> Technical Support >> controlling visibility with parameters
Mon, Dec 22, 2008 at 5:51:13 PM | controlling visibility with parameters
awhite
We are trying to create a tag family.  We would like to choose a single component to be visible and the other components (3) to not be visible.
e.g. A is on and B, C, and D are off
B is on and A, C, D are off etc...
We tried to use parameters to control the visibility of the components, but are having trouble making our formulas function in the way we anticipated them to.  We have read extensively in the help menu and on other RevitCity threads.  We are still unable to make this work.
We created the components in a family (each containing a label and a line).  Then we created yes/no parameters named A, B, C, and D.  We assigned each component (label and line) to A, B, C, or D parameter.  We attempted to enter formulas in the Family Types dialogue box.  We were unsuccessful with our syntax.
Any suggestions?
Wed, Dec 31, 2008 at 11:34:33 AM | controlling visibility with parameters
ChopperDave
There are a couple different ways you could do it. You could make them type parameters instead of instance and make a family type for each of the ones you want shown. Or you could create another parameter as an integer. It could be changed to 1-4 and you could set up formulas for the visibility "int = 1". "int = 2", etc.
Wed, Dec 31, 2008 at 11:53:55 AM | controlling visibility with parameters
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Here's how I handle this.
I create a parameter to controll the selection of the lable I want to see and set visibility parameters that will be driven by this.
 See attached image for how I set it up.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Controlling visibility in linked RVT files
Tue, Apr 18, 2006 at 1:29:10 AM
Key Schedules and Shared Parameters
Tue, Oct 7, 2008 at 3:14:43 PM
controlling transparency / visibility
Wed, Oct 24, 2007 at 4:59:24 PM
Controlling Visiblilty Of Multiple Families
Sun, Nov 4, 2012 at 10:16:48 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:39 AM
Page generation time: 0.2145
