Forums >> Revit Systems >> Technical Support >> Revit 2009 Out of memory
Sat, Dec 20, 2008 at 6:28:48 PM | Revit 2009 Out of memory
mel1322
I just got an error "out of memory".  I have been having trouble with my file for about 1 week. Have cleaned up whatever I can.  Removed unneeded dwg files, purged, saved, created new central file, ect.  Now this message.  The program is running very slow.  I even changed to a better computer.
2.40GHz
3GB Ram
Windows XP 2002
Any thoughts?
Thanks
Sun, Dec 21, 2008 at 5:42:02 AM | Revit 2009 Out of memory
4 Stars: 205 Votes
Hi, I had some kind of problems like that in the past, i have a Dual-core 2.40Ghz with 8Gb Ram, ATI graphic card 512Mb, use Vista 64Bits and i install Web Updates (1,2 and 3) for Revit 2009, now i work fine, no more issues, did you upgrade your Revit??? What is the size of your file??? Did you create lots of "Create-in-place" in the project???
Mon, Dec 22, 2008 at 8:38:30 AM | Revit 2009 Out of memory
mel1322
Thanks, I will try the updates.  Will see if that works.
Tue, Oct 29, 2013 at 11:36:32 AM | Revit 2009 Out of memory
maryamamanaty
I 'm working on a project that have 40 mega byte volume, how can i improve my system's speed. i have hp 4540s with 4Gb ram , corei5 2.6.
thanks.
Tue, Oct 29, 2013 at 11:58:44 AM | Revit 2009 Out of memory
Are you using 2009?  If not, then why did you tag onto this post instead of starting your own.
Look back through the posts and read about the 3GB switch.  We had to set that on our 4GB systems.
2009 memory requirements
Thu, Jul 10, 2008 at 4:08:14 PM
Revit 2009 Memory Issue? [ 1 2 ]
Sun, Oct 12, 2008 at 9:54:16 PM
16
I have enough memory but Revit doesn't agree about that
Sun, May 10, 2015 at 10:59:23 PM
Memory Hog
Fri, Jul 27, 2007 at 3:58:49 AM
Out of Memory
Mon, Apr 29, 2019 at 4:10:05 PM
Page generation time: 3.5805
