Forums >> Revit Building >> Technical Support >> Parameter Data - What's the difference between Constraints & Dimensions.
Sat, Dec 20, 2008 at 4:41:51 PM | Parameter Data - What's the difference between Constraints & Dimensions.
DaveF
HiI can find no explanation of the differences between these (in fact, all) options.One small difference I've noticed is Constraints don't grey out when a formula is added.But Other than that, I'm lost.Is there's a web page that I've missed that gives a description?
Cheers
Dave F.
Sun, Dec 21, 2008 at 5:29:48 AM | Parameter Data - What's the difference between Constraints & Dimensions.
tim123
4 Stars: 19 Votes
Can you describe your problem in a  bit more detail - what are you trying to do.  Dimensions can be constrained.
Sun, Dec 21, 2008 at 7:07:26 AM | Parameter Data - What's the difference between Constraints & Dimensions.
DaveF
Hi
Thanks for the reply.
I'm not trying to do anything specific, just trying to learn about when & where I would want to 'Group ParamterUnder' Dimensions, Constraints or Other etc.
I can find specifc example telling me which I should use, but only for that example & they give no reasons why.
I'm trying to find generic explanations of the usage.
Cheers
Dave F.
Sun, Dec 21, 2008 at 7:12:54 AM | Parameter Data - What's the difference between Constraints & Dimensions.
tim123
4 Stars: 19 Votes
Dave
If you are creating a family, it determines the location of the parameter in the Element property dialog box.  It does not really affect anything else - if I'm understanding your query correctly.
Sun, Dec 21, 2008 at 12:19:17 PM | Parameter Data - What's the difference between Constraints & Dimensions.
A constraint can be a dimension if it is locked ... another constrait might be an alignment with a lock.
Room Tag & Room Dimensions
Mon, Mar 13, 2006 at 3:11:05 PM
Family Instant Parameter Constraints Offset
Fri, Feb 1, 2013 at 2:41:00 PM
Change Change Parameter "Group Under" Category
Tue, Jun 21, 2016 at 2:04:10 PM
Parametric elliptical shape in family
Fri, Feb 20, 2015 at 4:30:19 AM
How to make a flexible radius parameter for pipe thicknesses?
Wed, Feb 8, 2012 at 12:55:42 AM
Page generation time: 2.2976
