18 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Linked view tag
Fri, Dec 19, 2008 at 5:10:37 PM | Linked view tag
stschritter
Is there a way to show view tags from a link drawing?
Sun, Dec 21, 2008 at 6:43:51 AM | Linked view tag
tim123
4 Stars: 19 Votes
You need to create the required views of your linked model within the host project.  Only the model (and annotations) are imported.  If you go to VG, Revit links, you can overide the host view settings to display the elements and annotations that you require.  You cannot turn on the view tags as they would refer to a different project.
2011 - Room Tags from a linked file
Thu, Aug 19, 2010 at 4:10:54 PM
View Templates Linked to Elevation Tags
Fri, Jul 15, 2011 at 1:05:51 PM
One Tag for Two Items
Wed, Mar 30, 2011 at 5:38:19 PM
Level tag in locked 3D view
Thu, Oct 5, 2017 at 8:17:39 AM
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Page generation time: 3.4501
