Forums >> Community >> The Studio >> Autocad 3d drawing in to Revit?
Wed, May 25, 2005 at 8:36:44 AM | Autocad 3d drawing in to Revit?
jmiller
My question is I am working with a interior designer that uses autocad to do there layout, and I want to bring those into Revit, they are drawing in 3d in cad but how can I use these in Revit and be able to change material on them or do ii have to do that in cad? Thanks jmiller
Thu, May 26, 2005 at 6:36:38 PM | RE: Autocad 3d drawing in to Revit?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
When importing a 3D autocad file the autocad materials are added into your material settings. If you find the appropriate named material you can change its map etc to what you require. HTH.
Fri, Jun 3, 2005 at 2:32:48 PM | RE: Autocad 3d drawing in to Revit?
rnipper
I have a similar concern. My boss wants to know whether or not we can create a project in ADT and then open it in Revit to create a bill of materials with little or no effort. Does anyone have any experience with this?
Sun, Jun 5, 2005 at 8:01:16 PM | RE: Autocad 3d drawing in to Revit?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is not possible. Revit can only schedule revit elements. you would need to remodel the ADT model in revit. You can use it as a 3D mass to then pick faces to apply walls floors etc... HTH.
I wish Revit had the same drawing commands available as AutoCAD!!
Sat, Feb 17, 2007 at 6:32:46 PM
Laying a 2d autocad drawing in revit
Fri, Jun 26, 2009 at 8:49:12 AM
How can i render the AutoCAD 3D Drawing in Revit
Thu, Apr 6, 2006 at 5:47:51 AM
Autocad Import Problems
Tue, May 5, 2009 at 1:55:33 PM
Hidden Elements in Autocad and not being able to explode drawing in Revit
Mon, Dec 2, 2013 at 4:04:47 PM
Page generation time: 1.6841
