Forums >> Revit Building >> Tips & Tricks >> roofs with different angle
Fri, Dec 19, 2008 at 6:00:33 AM | roofs with different angle
Dafpfy
3.5 Stars: 11 Votes
Hi, anyone got any tips or tricks on drawing this type op connection, ?
Kind regards,
D.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Dec 19, 2008 at 6:10:39 AM | roofs with different angle
4 Stars: 205 Votes
Hi, if that is a "Sweep", pick in the sweep go to Option menu and pick in "Change Return" then change the parameter to "Vertical" but write 45º, 60º "what ever"...
Edited on: Fri, Dec 19, 2008 at 6:11:48 AM
Fri, Dec 19, 2008 at 6:19:20 AM | roofs with different angle
Dafpfy
3.5 Stars: 11 Votes
no those are two roofs with a different angle cutting in plannview
peace is the path."
Mahatma Gandhi.
Fri, Dec 19, 2008 at 6:24:24 AM | roofs with different angle
4 Stars: 205 Votes
Can you post some images in 3D view to check????
Fri, Dec 19, 2008 at 6:39:10 AM | roofs with different angle
Dafpfy
3.5 Stars: 11 Votes
its kinda hard to get a good angle on it to make it clear, but hope this helpsEdited on: Fri, Dec 19, 2008 at 6:41:28 AM
Edited on: Fri, Dec 19, 2008 at 6:42:09 AM
peace is the path."
Mahatma Gandhi.
Fri, Dec 19, 2008 at 6:42:37 AM | roofs with different angle
Dafpfy
3.5 Stars: 11 Votes
peace is the path."
Mahatma Gandhi.
Fri, Dec 19, 2008 at 6:55:55 AM | roofs with different angle
4 Stars: 205 Votes
Well, did you use "Join/Unjoin Roof"??? That edge its a "Footprint" roof or what???
Fri, Dec 19, 2008 at 7:08:31 AM | roofs with different angle
Dafpfy
3.5 Stars: 11 Votes
the roofs are joined and both are roofs by extrusion.
peace is the path."
Mahatma Gandhi.
Fri, Dec 19, 2008 at 7:14:40 AM | roofs with different angle
4 Stars: 205 Votes
So if that edge its a extusion roof create a Elevation or Section View and Create-in-place in the same category (roof) a "Void" to "cut" those portions of roof you don't want...
Rotation angle of double angle roof bracing.
Mon, Jan 21, 2008 at 2:51:55 PM
Is this possible?
Tue, Aug 23, 2005 at 3:15:52 AM
Turning a roof down at a 90ͦ angle`
Wed, Sep 30, 2009 at 6:40:14 AM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed...
Wed, Sep 30, 2015 at 12:28:52 PM
Page generation time: 0.1297
