Forums >> Revit Building >> Technical Support >> Linked revit model keeps unloading.
Thu, Dec 18, 2008 at 12:15:57 PM | Linked revit model keeps unloading.
DaveF
Hi
When I save to central, every few times, a warnng message telling me it can't find the linked model & will unload.
I think the problem maybe that the Saved Path is still the consultants server path & not mine.
The local alias point to my server.
If this is the problem, how can I changed the saved path. If not, how do I fix this annoyance?
Cheers
Dave F.
Thu, Dec 18, 2008 at 1:53:54 PM | Linked revit model keeps unloading.
tim123
4 Stars: 19 Votes
You should be able to change the path from the Manage Links dialog box (under File menu).
Thu, Dec 18, 2008 at 2:12:22 PM | Linked revit model keeps unloading.
DaveF
Ah Yes, I see. i give that a go.
Also, this seems similar to my problem.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=10500
I'll give them a test.
Thanks for your reply.
What's the difference between Unloading a Linked Revit File and Removing? [ 1 2 ]
Mon, Feb 27, 2017 at 1:57:44 PM
16
Room Finish Schedule - Linked
Wed, Feb 17, 2021 at 3:52:40 PM
Visibility Graphics settings: saving them when unloading a linked model
Fri, Feb 25, 2011 at 1:54:00 PM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:28 PM
Not able to place room copied from linked model
Wed, Mar 18, 2015 at 8:10:37 AM
Page generation time: 2.3337
