10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Problems attaching railings to stairs
5 Posts No Rating |
Hi, I have a problem about my railings. The railings isn't attached to the stair itself - instead of that, they're hovering a bit above them. I was hoping there would be a simple solution for this, that I unfortunately missed during the proces of adjusting the stairs. Can someone please help me getting out of this problem? Thanks in advance  Best regards,Esben Ps. I'm using Revit 2009
Edited on: Thu, Dec 18, 2008 at 10:13:50 AM
38 Posts No Rating |
Looks like you removed your stringers but didn't move the railings. Nudge them over the stairs and you should be fine. Currently they are floating off to the side.
Yeah, select the rail, pick "Edit" and "Pick Host" in the stairs, this may correct the problem...
5 Posts No Rating |
Worked very fine. Thanks
0 Posts No Rating |
I had this same problem before. My fault was that I turned monolithic stairs on and ignored the warning messages. The stringer showed up again when I turned it off.
Archidea |
Attaching railings to stairs? |
Wed, May 24, 2006 at 1:48:05 AM
Attaching railings to precast stairs [ 1 2 ] |
Fri, Jan 16, 2015 at 6:37:53 PM
15
My railings doesn't go with my stairs |
Mon, Dec 2, 2013 at 11:45:03 AM
14
Attaching Railign to stairs... |
Sun, Jan 23, 2011 at 8:59:01 AM
Detailing/dimensioning stairs and railings |
Fri, Mar 16, 2007 at 2:14:13 PM
