Forums >> Revit Building >> Technical Support >> Splitting an elevation view
Wed, May 25, 2005 at 4:56:40 AM | Splitting an elevation view
Cherrysmoker
I hope I make sense with this question. We want to split our elevation in 2 parts and move the on closer into the buiding than the other to please our architects in the office :/ Do you think this is possible? I haven't had much luck with it but will keep on trying. Thanks guys.
Wed, May 25, 2005 at 10:12:46 AM | RE: Splitting an elevation view
TomDorner
4.5 Stars: 25 Votes
You could simply have two elevation views or you could do a callout from the main elevation. HTH Tom
Wed, May 25, 2005 at 7:04:12 PM | RE: Splitting an elevation view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Easy. Turn on the crop region in the elevation. Select the crop region then hit one of the split lines to break the elevation into two parts. (4 quiggly lines around the border of the crop region.) Then adjust each crop to the area you want to see. Then select one crop region and you'll notice there is now an arrow in the centre. Drag this to drag each section closer together... HTH.
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Splitting a wall in 3 EQ sized walls
Tue, Feb 5, 2008 at 11:51:51 AM
Making view titles reference each elevation
Mon, Oct 21, 2013 at 7:30:20 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Splitting a wall with a Reveal
Fri, Feb 19, 2010 at 11:25:44 AM
Page generation time: 8.6651
