Forums >> Revit Systems >> Technical Support >> How do I combine fields in a note block with fields in a room schedule?!?
Wed, Dec 17, 2008 at 10:51:27 AM | How do I combine fields in a note block with fields in a room schedule?!?
nhe8888
I am making a sign plan and schedule.  I made a room tag type with some shared parameters that allow me to schedule and tag the rooms with the text and the number that will be on the room sign. (vs the text and the number that appear on the architectural plans already which are in the normal name and number categories).  The problem is that I have created a note tag to point out where the signs for the rooms are.  It can't be a room tag type that I use because the signs will be posted OUTSIDE the rooms that they reference vs INSIDE.  I would like those plan mark notes to be linked to a category in the sign room schedule, but I can't figure out how to make it work.  Please help!!!
Wed, Dec 17, 2008 at 10:59:37 AM | How do I combine fields in a note block with fields in a room schedule?!?
Not the best fix .... but could you add a parameter to your door  (room number) and use a door tag?
Thu, Mar 4, 2010 at 3:51:58 PM | How do I combine fields in a note block with fields in a room schedule?!?
Luigiman
I am doing a sign plan also, and looking into all the options better suitable for this. What did you end up doing? I did the same thing (Room tag) but then there is no option to have a free end on/attached end on a Room tag....
Help
Multiple dimension fields in schedule
Wed, Aug 24, 2011 at 4:31:08 PM
Door Schedule Fields Clarification
Mon, Dec 3, 2012 at 7:06:53 AM
Schedules combining 2 text fields in to 1
Fri, Aug 10, 2007 at 12:27:28 PM
Door Schedule Problem - All Room Fields are Blank
Thu, May 30, 2013 at 7:40:46 AM
Putting custom fields in tags
Sat, Mar 10, 2012 at 8:39:31 AM
Page generation time: 0.2915
