Forums >> Revit Building >> Technical Support >> Family Questions in 2009
Wed, Dec 17, 2008 at 7:57:02 AM | Family Questions in 2009
JGATOR
I am trying to apply a certain brick pattern to a chimney to match the house. I went to edit the chimney family but it does not have the brick pattern. I have looked for the brick pattern to save to my computer but can not find it. How can I get a pattern that is in the project into the family I am editing so I can apply it to the family?
I am also trying to edit a garage door. The current door has two levels of glass panels. I only need one level of glass and the rest is opaque panels. When I copy an opaque panel to the area where the glass panel was it takes on the properties of the glass panels. How do I change those properties? I am still going through the help menu but no luck so far and I am in a time crunch.
Thanks for any help.
Wed, Dec 17, 2008 at 8:41:17 AM | Family Questions in 2009
You don't need to do it in the family.  Try this ...
  1. Open the family and identify the material assigned to the chimney
  2. If it is default - change that to something like"chimney brick"
  3. Load the family
  4. In your project, find chimney brick and assign the same material as your house walls.
Wed, Dec 17, 2008 at 9:20:49 AM | Family Questions in 2009
JGATOR
WWHub,
 That worked for the chimney, thanks. Any idea on the grage door?
Wed, Dec 17, 2008 at 10:35:54 AM | Family Questions in 2009
You need to spend some time learning how to build families.
  1. If the panels are all defined in one extrusion, then they will all be the same material.  In that case, edit theextrusion and remove the portion that you need to be different than add a new extrusion with it being a different material.
  2. If the panels are seperate extrusions - simple - just redefine one with a new material name and handle like you did with the brick.
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Adaptive family SOLID FORM questions
Thu, Mar 31, 2016 at 6:34:24 PM
Saving frpom 2010 to 2009
Wed, Jul 13, 2011 at 2:13:05 PM
Multiple Newbie Questions
Mon, Sep 23, 2013 at 8:47:23 AM
More reveal questions
Tue, Nov 23, 2010 at 6:14:09 PM
Page generation time: 1.7361
