Forums >> Revit Building >> Technical Support >> Problems in wall
Tue, Dec 16, 2008 at 3:09:35 PM | Problems in wall
tsunamile
These walls aren't continuos! (they are broken when I created) Why?  help me please! thank so much!
Tue, Dec 16, 2008 at 3:14:20 PM | Problems in wall
4 Stars: 205 Votes
What a hell is that? it's only in plan view or also in 3D view????
Tue, Dec 16, 2008 at 4:11:31 PM | Problems in wall
blake
3 Stars: 2 Votes
Are you working with phases?  If so you may have drawn your new walls on the existing phase.  Also try using the unjoin tool there.
Or you may have some walls hidden.
Wed, Dec 17, 2008 at 11:10:00 AM | Problems in wall
tsunamile
Hi all, Blake! I'm not sure... Am I working with phases?... so  when i using the unjoin tool, it's okey! But any time ... Walls are created to break cotinuously! How can i solve this?. Please show me detail more, don't you? Thank's
Wed, Dec 17, 2008 at 11:12:54 AM | Problems in wall
blake
3 Stars: 2 Votes
In your view property at the bottom what happens when you change the Phase from New Construction to Existing.
Or Hit your Lightbulb along the bottom and see if anything is revealed.
Sat, Dec 20, 2008 at 10:59:17 AM | Problems in wall
tsunamile
Thank's blake, I really did  that!
Sat, Dec 20, 2008 at 11:43:12 AM | Problems in wall
vicozzio
Ummm.... I never encounter this kind of problem before... just asking the same question like typhoon did, is it only happen in plan view or is it happen in 3D view too? did it happen from the first time you create that wall or did you already modify the wall? did you create it with a specific wall type or is it happening to all kind type of walls?
and blake's solution... is it worked? I think the reveal hidden object button (bulb button) is only to reveal all hidden object...
Wed, Dec 24, 2008 at 4:43:18 AM | Problems in wall
tsunamile
Thank's vicozzio, It's my fault... because i used "e"_ keyboard button same "erase"_ button in Acad! I found out "e" mean hidden Obj. Hit Lightbulb the bottom and anything is revealed.... So can you tell me about "wall make bearing" appear when i creat a beam under corner wall which have no any structure column here!  Hope received  your answer soon.  Thank's
Thu, Dec 25, 2008 at 9:24:16 PM | Problems in wall
blake
3 Stars: 2 Votes
I believe the make wall bearing is mainly for the structural people.  If you make it bearing the structural guys will see those walls in their model and know which walls to copy/monitor.
If your structural consultants are not on revit you can ignore if you like.
Mon, Jan 12, 2009 at 2:14:28 AM | Problems in wall
tsunamile
Thank's blake!
 I have These Instanse:
 when wall reveal did not intersect at corner wall and wall sweep is same, too. And I did modified them correctly, After array and make group (during array command), all of new goup don't meet at coner. What can I do? (note: All wall are only one style)
Mon, Jan 12, 2009 at 8:37:31 AM | Problems in wall
#11
blake
3 Stars: 2 Votes
 If you dont want your wall sweep/reveal to go from one wall end to another and you have many of the same ones on a wall; consider making a family that is a reveal or sweep.  Make it wall hosted then have a the length parametric.  Then you can copy and past them and they will all be the same.
Wall Join Problems [ 1 2 ]
Tue, Feb 23, 2010 at 1:21:20 PM
15
Wall Trim Command Problems
Wed, Jul 14, 2010 at 12:47:15 PM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
2016 Stacked wall problems
Tue, Apr 5, 2016 at 12:03:48 PM
Problems with Stacked walls
Mon, Dec 21, 2009 at 3:01:20 PM
Page generation time: 1.6640
