25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> export to cad without the siding
126 Posts No Rating |
Hello, I have been exporting my revit files to Autocad for the structural engineer to work on becuase they work in Autocad. Is it possible to just export the framed wall and not all the siding and sheetrock? Thanks, RainaMc
If you go to the export options, then the layer settings, it looks like you can set different layers to the different layers of the wall (structure, air layer, sheathing etc.). So, you should be able to have it put those parts of the wall the structural guys don't need on a separate layer. That's not quite as good as not exporting them at all, but it at least makes it easy to filter out the unneeded stuff in ACAD.
That helps! Thank you,
I can“t export from revit to cad. |
Fri, Jan 18, 2013 at 9:10:32 AM
Revit Export to CAD |
Mon, Jul 21, 2014 at 8:35:51 AM
Revit export to CAD |
Mon, Oct 4, 2010 at 4:43:05 PM
How to export CAD with custom subcategory layer |
Tue, Feb 15, 2011 at 10:08:37 AM
Metal siding |
Mon, Mar 16, 2009 at 9:44:10 PM
