Forums >> Revit Building >> Technical Support >> walkthrough
Tue, Dec 16, 2008 at 9:12:08 AM | walkthrough
pstlouis
1 Stars: 2 Votes
I am using revit 2009 and trying to use the walkthrough feature then exporting the render images into a video format ( avi ). however no matter how may frames I used or how high of a render setting I set to the end result is a very fuzzy low res video. Is there a particular tutorial or proper setting I can look into. Any info will be greatly appreciated.
Wed, Oct 29, 2014 at 12:58:48 AM | walkthrough
archjahz
archjahz Avatar
Do not use the preinstalled codec in revit because it is hopeless.
Download Lagarith Lossless Codec--this does wonders.
Also make sure your graphic display settings is set to realistic with no edges. You can also tick photographic exposure to adjust the lighting of your video.
Also, a bit of advice when exporting walkthrough frames of very large models: do them by batch. I usually do 1-200, 201-400, 401-600, etc. You can them stitch them or append them together using Virtualdub (free).
Usually the resulting video will be very big as well (mine reached to 20gb for a 2-min video). So u can use Any Video Converter to convert these videos into smaller files without losing much quality. Smile
Hope this helps. Good luck!
Archidea
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
walkthrough questions
Sun, May 10, 2009 at 7:49:41 PM
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:12 PM
walkthrough
Wed, Aug 1, 2012 at 5:43:43 PM
Walkthrough
Thu, Sep 24, 2009 at 8:24:31 AM
Page generation time: 0.5774
