16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> section head problem?
160 Posts No Rating |
I created a duplicate section head tag in the Revit Library Annotations Folder. Went into " settings / View tags" and selected the appropriate tag. End result was gap between section head and line. realized the distance was proportionate to the size reduction I wanted. went back into Revit Library Annotations Folder and moved the section head with annotation closer to the end of the line. got the result shown below. Needless to say I'm stumped because my modification the section head in Library Annotation Folder still shows the annotation properly placed inside the circle of the section while on the sheet it shows the annotation outside the circle. Any thoughts as to why the annotation doesn't display as it is represented in the library folder?? The black image shows the library folder section the blue shows its representation in the actual drawing.
when i made the changes to the section head in the library folder I wrapped the lines and annotations in one command and shited them the proper distance.
2 Posts No Rating |
How did you end up solving the problem? I've tried moving the reference planes in the secton head, but that doesnt seem to do anything.
Thanks!
30 Posts No Rating |
I have the same proble and have seen others in various boards with the same problem, but NO suggested solutions.
WHAT VERSION
problem with section head |
Sun, Nov 26, 2006 at 4:49:05 PM
Section Head |
Fri, Nov 21, 2008 at 5:23:37 AM
Trying to Import Filled Section Head |
Mon, Jun 27, 2016 at 2:32:45 PM
Section Head |
Thu, Nov 11, 2010 at 2:21:51 PM
custom section head rotation (2019) |
Fri, Dec 14, 2018 at 9:28:45 AM
