27 Users Online (25 Members):
Forums >> Revit Structure >> Tips & Tricks >> Can't attach circle void
6 Posts No Rating |
I am trying to create a universal baseplate for steel columns. I have created a extrusion and voids to create a plate with holes. I had locked all the diminsions to be instance type parameters so the length width and thickness is controled by the user. Now I need the holes to be spaced accordingly and sized for anchorbolts. BUT, I can not get the void circles to lock to any reference plane! Now I am stuck because the holes will not move with any parameters and sets still where ever I placed them in the family editor. Someone please help! I am trying a new field in REVIT in which steel detailing can be accomplished. This will not only improve my acuracy but also maybe a way to make some extra dough. Thanks.
Images of what are you trying to do was fine....
Draw a reference planes and then create your void extrusion using the ref planes as a setout point for your void extrusion. The holes should move with the ref planes.
6 Posts No Rating |
Thanks Tim! I have just finished my little project and had uploaded it into the gallery. It is called "column with base plate and cap plate" (how original). Check it out.
How tags attach to elements |
Tue, Jul 22, 2008 at 11:20:12 AM
Attach wall based items to Void extrusion-Nested families |
Wed, Aug 28, 2019 at 1:58:19 PM
Mass Geometry Flaw | Circle points |
Fri, Dec 4, 2015 at 4:04:46 PM
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
Constraining a circle centered between two reference planes |
Fri, Apr 7, 2017 at 8:22:50 AM
