Forums >> Revit Building >> Technical Support >> columns from Modelling menu don't respond to level assignments
Fri, Dec 12, 2008 at 4:13:33 PM | columns from Modelling menu don't respond to level assignments
rquist
Modelling:     Column:
inserted wood timber column
When I assign the top constraint to "top of first floor wall "  the column is non-responsive in the drawing.
Basically trying to show wall framing elevation with king studs and shoulder studs.
Am I going about this wrong.
Fri, Dec 12, 2008 at 7:11:58 PM | columns from Modelling menu don't respond to level assignments
jarosa
jarosa Avatar
4 Stars: 5 Votes
I noticed you have a top of first floor wall and a second floor. Recheck the level you are associating the column to.
HTH,
John
Sat, Dec 13, 2008 at 12:45:38 AM | columns from Modelling menu don't respond to level assignments
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Edit the family and make sure the top of your column is locked onto the level plane. Does it respond to any change in height? Did you make this column yourself?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Sat, Dec 13, 2008 at 2:38:44 PM | columns from Modelling menu don't respond to level assignments
ICON1962
I also access Revit City from home using this i.d.
I created the column by duplicating an existing column from the browser.
the attachment shows the element properties. I do have the base assigned to the proper level
also placed the 5x5 columng that the 2x4 column originated from- it behaves in the same fashion
Sat, Dec 13, 2008 at 2:44:27 PM | columns from Modelling menu don't respond to level assignments
ICON1962
no it doesn't respond to any height inputs that I've tried,  grips or level assignments
Sun, Dec 14, 2008 at 6:13:10 PM | columns from Modelling menu don't respond to level assignments
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Can you please upload your file so we can have a look at it?
Mon, Dec 15, 2008 at 1:37:55 PM | columns from Modelling menu don't respond to level assignments
rquist
I've tried uploading it twice, but it times out and aborts the upload
Mon, Dec 15, 2008 at 7:11:30 PM | columns from Modelling menu don't respond to level assignments
jarosa
jarosa Avatar
4 Stars: 5 Votes
are you trying to upload the family? that should upload fine. the project is probably too big to upload though.
Tue, Dec 16, 2008 at 10:27:38 AM | columns from Modelling menu don't respond to level assignments
rquist
thanks for that tidbit.
I was looking at some pipe column familes which behave properly so I was going to find a different column that I could duplicate and edit.
Haven't worked with families much so I'm sure the 2x4 just isn't made right. I think I need to go back into the family and work on the extrusion properties.
I'm pretty sure I just have some basic issues with this so I'm not looking for anything too indepth, just a point in the right direction.
Tue, Dec 16, 2008 at 1:04:06 PM | columns from Modelling menu don't respond to level assignments
TJKENNEDY
3 Stars: 2 Votes
Did you attach the top or bottom to anything (floor)? If it's attached, any adjustment you try to make will be ignored.
Tue, Dec 16, 2008 at 2:55:17 PM | columns from Modelling menu don't respond to level assignments
#11
rquist
If you mean the same attach command that you'd use to attach wall to roof, the answer is no.
Not having created too many families yet I'm not aware if there is a way to "attach" in the process of creating the family.
Tue, Dec 16, 2008 at 4:25:47 PM | columns from Modelling menu don't respond to level assignments
#12
TJKENNEDY
3 Stars: 2 Votes
I was indeed refering to the attach command used to attach colums to roofs and floors. It sounds like that's not the problem however.
Wed, Dec 17, 2008 at 3:01:17 PM | columns from Modelling menu don't respond to level assignments
#13
ICON1962
I just found a working column.  I'm sure I'll figure out the problem when I learn how to create families from scratch.
Wed, Dec 17, 2008 at 3:41:18 PM | columns from Modelling menu don't respond to level assignments
#14
jarosa
jarosa Avatar
4 Stars: 5 Votes
I loaded the column into the project and set the top offset to 5' and it worked. I'm not sure what the problem you are having is.
columns wont host to level
Tue, Feb 27, 2018 at 3:59:01 PM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
columns don't show up in section elevations
Thu, Mar 20, 2008 at 1:58:07 PM
Attaching columns to roofs?
Wed, Jan 11, 2006 at 5:59:55 PM
need to lean columns to match shifting grid
Mon, Sep 24, 2007 at 1:20:52 PM
Page generation time: 2.6264
