11 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View properties "cut plane" option greyed out?
Thu, Dec 11, 2008 at 3:59:31 PM | View properties "cut plane" option greyed out?
rquist
Any thoughts as to why the "cut plane" option is greyed out??
Thu, Dec 11, 2008 at 6:57:03 PM | View properties "cut plane" option greyed out?
coreed
coreed Avatar
4 Stars: 16 Votes
because the cut-plnae is always associated to the level that you are on and should not be associated to another level from the current level. you can ajust it's offset from that level. but you cannot associate it to a level that is different than the current level you are on. at least i think that's how it is intened to work. maybe someone else can shed more light on the subject.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:42 PM
"visibility in option" in the properties box
Tue, Oct 28, 2014 at 1:13:46 PM
View Range > Cut Plane - Greyed out?
Fri, Sep 7, 2007 at 3:46:17 PM
Cut plane in family
Mon, Aug 13, 2007 at 1:25:23 PM
Page generation time: 6.4829
