Forums >> Revit Building >> Technical Support >> How do you adjust the size of a section head?
Thu, Dec 11, 2008 at 11:24:26 AM | How do you adjust the size of a section head?
rquist
I went thru the same process that I used for adjusting the text size of the level identification?
Opened up the the a section head file from the materials library
saved as something else
made necessary changes
loaded into project.
I don't get the new option in the "section tag" drop down box that's found in the "Element Properties", "type properties",  dialogue box.
Is it the same process?
Thanks
Sat, Dec 13, 2008 at 10:51:36 AM | How do you adjust the size of a section head?
tim123
4 Stars: 19 Votes
Go to settings / View tags and create the type there will your new tag.  You will then have the option to edit the section properties and apply the type.
Tue, May 4, 2010 at 5:53:59 PM | How do you adjust the size of a section head?
k1w1
-Adjust the Section Head and Section Tail families
-Then go to Manage --> Settings --> Section Tags
-Duplicate Type (make custom name).  For the Section Head and Section Tail pulldown, select the head/tail families you edited and saved.  Apply. Ok. Ok.
-Then in your drawing, click on the tag that is too big, and go to Element Properties.
-Click 'Edit Type'.  Duplicate Cryingor not) and select your custom Section Tag type from the 'Section Tag' pull down.
Section Tag Head Size
Thu, Feb 28, 2008 at 10:51:57 AM
Trying to Import Filled Section Head
Mon, Jun 27, 2016 at 2:32:45 PM
problem with section head
Sun, Nov 26, 2006 at 4:49:05 PM
Section Head
Thu, Nov 11, 2010 at 2:21:51 PM
How to make section marks smaller?
Wed, May 9, 2007 at 4:47:08 PM
Page generation time: 3.3776
