Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit Presentation Environment
Wed, Dec 10, 2008 at 3:08:53 PM | Revit Presentation Environment
nijM
Hello all. I've recently descovered the ability to export projects to DWFX format, at first this seamed very promising, I find the revit environment very good for presenting projectd IE. cropping 3d models to reveal the inner workings of the project jumping to sections etc however this can requier alot of machine power, very inconvieniet while presenting your work live, what i found in the DWFX format is a light weight solution to this problem virtually possible on the weakest of machines, however I was disapointed to find out that I can either export individual 2d sheets (much like creating a PDF book) or 3D data as a single model. What I'd like is to export my entire project to an environment where I could quickly jump betwin 2d and 3d elements of the presentation without having to burn my CPU.
I apologize for the longwindedness.
Please shed some light
nijM
Wed, Dec 10, 2008 at 4:25:40 PM | Revit Presentation Environment
Export your 3d dwf's and 2d dwf's then open one or the other.  Now, with your vieport tiled so that you can see your other files, simply drag and drop them into your open dwf....  you can also drag and drop excell and word files ... others too probably like jpg's....
Try it!!!!
Wed, Dec 10, 2008 at 5:25:39 PM | Revit Presentation Environment
nijM
Exellent! Thank you very much!
Fri, Feb 13, 2009 at 6:01:07 PM | Revit Presentation Environment
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
get an hp 8710 with 4 gb ram...it has a nvidea 1500m...its a mobile workstation. if you want one a little cheaper the hp 9440 is the exact same just older model...beisdes taking your model to a dwf defeats the purpose of bim...no i...
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Sharing Coordinates Conceptual Mass Environment and Project Environment
Sat, Nov 16, 2013 at 10:14:00 AM
Question about presentation settings
Mon, Jul 16, 2007 at 4:24:50 PM
ramps presentation [ 1 2 ]
Thu, Jan 8, 2015 at 8:53:24 AM
17
Revit and IES Virtual Environment
Fri, Feb 13, 2009 at 6:25:01 PM
14
Best Software to Create Presentation Floor Plans
Fri, Apr 30, 2010 at 12:56:47 AM
Page generation time: 4.2643
